GeoCocky66
PFW79
Rooster'srule
TAFC 5 1981
**USC (23-17) vs. Fu (2346)
Wilder and Thompson (814)
Landon Powell 39-6 a (790)
College Football Is (637)
2019 - Zovon Lindsay (538)
TRANSFER PRANK: NFL (337)
Woman cuts off man's (290)
Quincey Guerrier (240)
Scientists: Uranus S (149)
2 football transfers (18)
Discussion: 2019 Recruiti
2 football transfers anno
College Football Is Comin
Rakym Felder
**USC (23-17) vs. Furman
Landon Powell 39-6 at NGU
Quincey Guerrier
Wilder and Thompson trans
Gamecocks win Palmetto Se
2019 - Traevon Kenion
Old 11-07-2012, 01:59 PM   #1
Heisman Winner
2000grad's Avatar
CockyCash: 1233026
2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material
Default Foggy Headlamps
Is there any product that really does clean and clear the fogged up headlamps on a car?
2000grad is offline   Reply With Quote
Old 11-07-2012, 02:12 PM   #2
LeeSC
Melvin bowls...overhand.
LeeSC's Avatar
LeeSC is USC mascot materialLeeSC is USC mascot materialLeeSC is USC mascot materialLeeSC is USC mascot materialLeeSC is USC mascot materialLeeSC is USC mascot materialLeeSC is USC mascot materialLeeSC is USC mascot materialLeeSC is USC mascot materialLeeSC is USC mascot materialLeeSC is USC mascot material
Default Re: Foggy Headlamps
If you are talking about haze on the outside, Auto parts stores sells some stuff...but it is really just a polishing compound. If they are made of plastic material the polishing compound will work quite well....I haven't it them on the glass type.
LeeSC is offline   Reply With Quote
Old 11-07-2012, 02:51 PM   #3
warriorchief
CT's 2x Favorite Tiger
warriorchief's Avatar
2009 Awards: Awards for best Posters - Given for: Favorite Non Gamecock Poster
CockyCash: 540000
warriorchief is USC mascot materialwarriorchief is USC mascot materialwarriorchief is USC mascot materialwarriorchief is USC mascot materialwarriorchief is USC mascot materialwarriorchief is USC mascot materialwarriorchief is USC mascot materialwarriorchief is USC mascot materialwarriorchief is USC mascot materialwarriorchief is USC mascot materialwarriorchief is USC mascot material
if you can find it, use the Sylvania Headlight Restoration kit, works amazingly well. If you can't, the one by 3M is just as good.
warriorchief is offline   Reply With Quote
Old 11-07-2012, 03:37 PM   #4
ccured
ccured's Avatar
CockyCash: 74000
ccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot material
you don't need a kit. just need toothpaste make sure it is toothpaste not gel, glass cleaner, and a sock. basically wet sand it. once you get them clean. wax them with a few coats of wax to keep them from fogging
ccured is offline   Reply With Quote
Old 11-07-2012, 04:24 PM   #5
M.C.
Gamecock4Life
M.C.'s Avatar
CockyCash: 8949643
M.C. is USC mascot materialM.C. is USC mascot materialM.C. is USC mascot materialM.C. is USC mascot materialM.C. is USC mascot materialM.C. is USC mascot materialM.C. is USC mascot materialM.C. is USC mascot materialM.C. is USC mascot materialM.C. is USC mascot materialM.C. is USC mascot material
Send a message via AIM to M.C.
there are alot of them out there and yes they work i was surprised
All you Clemson Tigers Can Kiss My Garnet Ass -M.C.
M.C. is offline   Reply With Quote
Old 11-07-2012, 04:33 PM   #6
simsar4
moram focus
simsar4's Avatar
CockyCash: 243
simsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot material
I'm gonna have to try this, what about the condensation on the inside of the light?
<img src=http://img3.etsystatic.com/il_170x135.236817435.jpg border=0 alt= />
simsar4 is offline   Reply With Quote
Old 11-07-2012, 04:54 PM   #7
ccured
ccured's Avatar
CockyCash: 74000
you will have to find the leak the seal. dry with a hair dryer. then use silicone to re-seal. then trim excess silicone.
Old 11-08-2012, 11:21 AM   #8
Heisman Winner
2000grad's Avatar
CockyCash: 1233026
The youtube trick did not work
Old 11-08-2012, 11:41 AM   #9
TruckGuy
TruckGuy's Avatar
CockyCash: 350
TruckGuy has earned his spursTruckGuy has earned his spursTruckGuy has earned his spursTruckGuy has earned his spursTruckGuy has earned his spursTruckGuy has earned his spurs
We use a kit at our shop from BG chemical company. but the ones you can get at parts houses work, just make sure you get a kit that has 2 different grades of sand paper. Use the rougher paper with the cleaner first, clean off, then use the lighter paper with cleaner and rub them very good. Clean that off with glass cleaner. They will look like crap. You have scratched the lenses up, but removed the outer layer that has faded from sunlight. When you apply the epoxy resin with applicator, it will fill in all the fine scratches and they will look brand new. Promise. Crank vehicle and turn high beams on for about 20 mins to let the epoxy dry. This is important...DO NOT DRIVE VEHICLE WHILE EPOXY IS STILL TACKY!!! Do the finger test in a corner of lens to make sure it is dry. Driving while tacky will pick up dirt, debris and bugs. It is easier than it sounds and will last for at least a year or two.
TruckGuy is offline   Reply With Quote
Old 11-08-2012, 11:50 AM   #10
Heisman Winner
2000grad's Avatar
CockyCash: 1233026
can you tell me the actual name of the product?
Old 11-08-2012, 11:58 AM   #11
The Yancey's Avatar
2009 Awards: Awards for best Posters - Given for: Best Signature
CockyCash: 4751350
The Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot material
I thought that this thread would be about boob shots on a foggy day.
The Yancey is offline   Reply With Quote
Old 11-08-2012, 01:59 PM   #12
4Ever2Thee
4Ever2Thee's Avatar
CockyCash: 2940
4Ever2Thee rules the CockPit4Ever2Thee rules the CockPit4Ever2Thee rules the CockPit4Ever2Thee rules the CockPit4Ever2Thee rules the CockPit4Ever2Thee rules the CockPit4Ever2Thee rules the CockPit4Ever2Thee rules the CockPit4Ever2Thee rules the CockPit4Ever2Thee rules the CockPit4Ever2Thee rules the CockPit
It can be both, that could really liven up this thread
4Ever2Thee is offline   Reply With Quote
