Go Back   CockyTalk > Community > The Water Cooler > Carolina Eats
keegthecock
MountainCock
Lonnie
PvtWarlick
Tornado in Oklahoma (1565)
Clowney for Heisman (1100)
The 92 million dolla (687)
TV info (588)
How many states have (539)
Who's going to Hoove (491)
2017 - Savales Cann (390)
SEC arms race contin (331)
Ray Manzarek Dies... (320)
Phone Thief Gets Ins (302)
2015 - Shameik Blackshear
***2013 SEC Baseball Tour
Next-Box coming 5-21
Super Bowl L and LI
2014 - Ryeshene Bronson -
Freaks List: Clowney
VA RB Clifton Richardson
Call of Duty: Ghost (Nove
South Carolina vs Arkansa
2014 - Christian Miller
Old 11-07-2012, 05:56 PM   #1
cockypanther
cockypanther's Avatar
CockyCash: 356
cockypanther is USC mascot materialcockypanther is USC mascot materialcockypanther is USC mascot materialcockypanther is USC mascot materialcockypanther is USC mascot materialcockypanther is USC mascot materialcockypanther is USC mascot materialcockypanther is USC mascot materialcockypanther is USC mascot materialcockypanther is USC mascot materialcockypanther is USC mascot material
Default Chicken Marinade
I know some of y'all out there have a good recipe for marinated chicken. Basically what I am looking for is a recipe/seasoning/spice blend that doesn't take terribly long (maybe hour to hour and a half max to marinade) and has a fantastic taste! Unfortuantely I am living in an apartment and do not have access to a grill, so I am looking to cook the chicken on either a pan on the stove top or in the oven. Let's see what y'all got.
cockypanther is online now   Reply With Quote
Old 11-07-2012, 06:02 PM   #2
Kickerspl80
Too Deep
Kickerspl80's Avatar
CockyCash: 10000692
Kickerspl80 is USC mascot materialKickerspl80 is USC mascot materialKickerspl80 is USC mascot materialKickerspl80 is USC mascot materialKickerspl80 is USC mascot materialKickerspl80 is USC mascot materialKickerspl80 is USC mascot materialKickerspl80 is USC mascot materialKickerspl80 is USC mascot materialKickerspl80 is USC mascot materialKickerspl80 is USC mascot material
Default Re: Chicken Marinade
Where's Cack and Yancey when u need em! Im also looking for something similar just to try something new. I dont care about time it takes o marinade tho.
Im cooking Chicken Parm tonight woop woop!
Kickerspl80 is offline   Reply With Quote
Old 11-08-2012, 05:54 PM   #3
cockypanther
CockyCash: 356
Bump. Looking for some help here... Yancey, Cack... I'm looking @ y'all.
Old 11-08-2012, 06:07 PM   #4
cocky0
The Slurp
cocky0's Avatar
2009 Awards: Awards for best Posters - Given for: Best Signature 2008 Cockytalk Award: 2008 Cockytalk Award - Given for: 2008 Fark of the Year Christmas Farking Contest: Christmas Farking Contest - Given for: Winning Farking Contest
CockyCash: 25065000
cocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot material
Send a message via Yahoo to cocky0
Here's one I've used on pork chops, but it was meant for chicken.
1 (4 to 5-pound) broiler fryer chicken
1 quart water
1/2 cup honey
3 1/2 ounces kosher salt, approximately 3/4 cup
1 tablespoon curry powder
1 tablespoon chili powder
2 teaspoons cocoa powder
1 teaspoon adobo powder, without pepper
1 teaspoon ground cumin
1 teaspoon hot smoked paprika
Special Equipment: 2 pieces newspaper, vegetable oil, 2 to 3 pounds natural chunk charcoal, charcoal chimney starter, 8 feet heavy duty aluminum foil, 2 aluminum pie pans
Directions
Lay the chicken on a plastic cutting board, breast side up, with the neck facing you. Remove both wings at the joint between the wing and drumette. Remove the thigh quarters by slicing down on either side of the back end of the breast. Grab both legs, pop the joints that connect to the back, and turn the bird over. Remove the thighs and legs by slicing where they attach to the backbone. Hold the thigh and leg together, feel for the slight indentation where the joints meet and make an incision at this joint. Set the leg and thigh down and slice to separate. Repeat with the other leg piece. Turn the bird back over, breast side up, put your knife against the breastbone and slice down along the rib cage, cutting the breast meat away from the bone. Be sure to include the drumette when removing the breast. Repeat on the other breast. Freeze the carcass for making stock or discard.
Put the chicken pieces in a 1 gallon resealable plastic bag with the water, honey, and salt. Seal the bag and move around vigorously for 1 to 2 minutes to distribute the honey and dissolve the salt. Set the bag in a leak-proof container and refrigerate for 1 1/2 hours.
Meanwhile, combine curry powder, chili powder, cocoa powder, adobo powder, cumin, and hot smoked paprika in a 1 gallon resealable bag.
Pat the chicken with paper towels until very dry. Do not rinse.
Put the chicken in the bag with the spice mixture and shake to thoroughly coat the chicken. Lay the pieces on a cooling rack set inside a half sheet pan. Rest for 30 minutes.
cocky0 is offline   Reply With Quote
Old 11-08-2012, 06:14 PM   #5
ShutTheSuccop
Go Cocks!
ShutTheSuccop's Avatar
CockyCash: 97950
ShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot material
buy Spiedie's Sauce in the marinade area of the grocery store. It is quick!
www.spiedie.com
ShutTheSuccop is offline   Reply With Quote
Old 11-08-2012, 06:21 PM   #6
USCfootball
USCfootball's Avatar
USCfootball has hatched from the shell
Italian dressing - that's all. Marinade and then add salt/pepper/garlic powder as it cooks to your liking.
USCfootball is offline   Reply With Quote
Old 11-08-2012, 06:31 PM   #7
ccured
What a Rush!!!
ccured's Avatar
CockyCash: 3052976
ccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot material
Italiandressing and liquid smoke
ccured is offline   Reply With Quote
Old 11-08-2012, 07:01 PM   #8
Frosty
Frosty's Avatar
CockyCash: 84350
Frosty has developed his gaff and talonsFrosty has developed his gaff and talonsFrosty has developed his gaff and talonsFrosty has developed his gaff and talonsFrosty has developed his gaff and talonsFrosty has developed his gaff and talonsFrosty has developed his gaff and talonsFrosty has developed his gaff and talonsFrosty has developed his gaff and talonsFrosty has developed his gaff and talonsFrosty has developed his gaff and talons
I use a Zesty Italian for chicken. If you have a Harris Teeter near you check the fresh meat section, they sell Fresh never frozen chicken breasts for $1.99/lb. The bag the breasts come in works fine for adding some of the dressing to it.
Frosty is offline   Reply With Quote
Old 11-08-2012, 07:10 PM   #9
darthtripous
darthtripous's Avatar
darthtripous is sharpening his clawsdarthtripous is sharpening his clawsdarthtripous is sharpening his clawsdarthtripous is sharpening his clawsdarthtripous is sharpening his claws
The key to cooking chicken is a brine. you can marinade all you want, but a brine helps to chemically alter the meat structure so that when put to heat to the meat it holds its juices and flavor. all you do is let the chicken sit in a mixture of salt and water, let it dry, and then put on your marinade. Use google.. its easy and your wont eating charcole chicken
darthtripous is offline   Reply With Quote
Old 11-08-2012, 07:26 PM   #10
Cocky2001
Cocky2001's Avatar
Cocky2001 is USC mascot materialCocky2001 is USC mascot materialCocky2001 is USC mascot materialCocky2001 is USC mascot materialCocky2001 is USC mascot materialCocky2001 is USC mascot materialCocky2001 is USC mascot materialCocky2001 is USC mascot materialCocky2001 is USC mascot materialCocky2001 is USC mascot materialCocky2001 is USC mascot material
Yancey must be "otherwise occupied" ... saw the thread and took a look to see what he had posted. Not like my buddy to be slow in responding, but I'll check back.
Like the brine idea, I usually just do the italian dressing w/o the brine, will try it though.
"Fear causes hesitation,
And hesitation causes
Your worst fears
to come true." Bodhi.
Cocky2001 is offline   Reply With Quote
Old 11-08-2012, 07:53 PM   #11
cocky0
The Slurp
cocky0's Avatar
CockyCash: 25065000
I'll second the italian dressing nomination. Sometimes I use the dry mix with my fried chicken dredge.
Old 11-08-2012, 08:12 PM   #12
The Yancey's Avatar
CockyCash: 4751450
The Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot material
You are screwing yourself with that time limitation. I agree with the earlier poster that brining is the way to go with larger pieces. If you have a short time and are using cut up pieces try going with a commercial mojo marinade. Publix sells bottles. It will give you a nice taste of the islands.
The Yancey is offline   Reply With Quote
Old 11-08-2012, 09:06 PM   #13
hellraiser24
hellraiser24's Avatar
CockyCash: 1384
hellraiser24 is USC mascot materialhellraiser24 is USC mascot materialhellraiser24 is USC mascot materialhellraiser24 is USC mascot materialhellraiser24 is USC mascot materialhellraiser24 is USC mascot materialhellraiser24 is USC mascot materialhellraiser24 is USC mascot materialhellraiser24 is USC mascot materialhellraiser24 is USC mascot materialhellraiser24 is USC mascot material
Check out this thread:
http://www.cockytalk.com/showthread....hlight=chicken
"I can do all things through Him who gives me strength" - Philippians 4:13
hellraiser24 is offline   Reply With Quote
Old 11-08-2012, 09:27 PM   #14
cockypanther
CockyCash: 356
Threw a lil bait and look what I got haha. I'm definitely going to try some of these and it looks like Italian dressing is a popular marinade.
Old 11-08-2012, 10:29 PM   #15
2spurs
2spurs's Avatar
2spurs is making other chickens nervous2spurs is making other chickens nervous2spurs is making other chickens nervous2spurs is making other chickens nervous2spurs is making other chickens nervous2spurs is making other chickens nervous2spurs is making other chickens nervous2spurs is making other chickens nervous
Here is one I picked up while living in Mexico that is real good for Chicken/Fish/Shrimp. (especially when used for fajitas)
2 tablespoons Olive oil
1/3 cup lime juice
1/3 cup lemon juice
1/3 cup orange juice
1 1/2 tablespoons minced garlic
1 teaspoon dried oregano
3/4 teaspoon ground cumin
1 bay leaf
Salt/pepper to taste
Add around 1/2 cup of of your favorite salsa...I make my own. However store bought will work fine.
place in your blender then seal it up in a zip-lock for 2-4 hours in the fridge.
Take it out 30 minutes to an hour before grilling
2spurs is offline   Reply With Quote
Old 11-12-2012, 02:20 PM   #16
5150harley
Sandlapper Pools
5150harley's Avatar
5150harley is USC mascot material5150harley is USC mascot material5150harley is USC mascot material5150harley is USC mascot material5150harley is USC mascot material5150harley is USC mascot material5150harley is USC mascot material5150harley is USC mascot material5150harley is USC mascot material5150harley is USC mascot material5150harley is USC mascot material
I like to mix Italian and Worcestershire in a bag about half and half. Put boneless breast in and let marinate for a couple of hours shaking the bag up a couple of times.
Also, like to put sliced pineapples in the bag with a little juice and cook the pineapples on the grill.
5150harley is offline   Reply With Quote
Old 11-12-2012, 05:41 PM   #17
sandstorm2001
sandstorm2001's Avatar
CockyCash: 100700
sandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot material
When I make chicken parm I like to let the chicken sit in Lemon juice and garlic for no more than 20 or 30 minutes (depending on how strong you want to lemon flavor to be), then bread it in a mixture of flour and cavenders and fry it in olive oil. Comes out pretty fantastic.
sandstorm2001 is offline   Reply With Quote
Old 11-12-2012, 08:56 PM   #18
LimpCock
Blackout
LimpCock's Avatar
CockyCash: 13758453
LimpCock rules the CockPitLimpCock rules the CockPitLimpCock rules the CockPitLimpCock rules the CockPitLimpCock rules the CockPitLimpCock rules the CockPitLimpCock rules the CockPitLimpCock rules the CockPitLimpCock rules the CockPitLimpCock rules the CockPitLimpCock rules the CockPit
^^ lemon juice and cavenders
If I get an erection that lasts for more than four hours, she's going to be the one going to the hospital.
LimpCock is offline   Reply With Quote
Old 11-12-2012, 08:59 PM   #19
simsar4
...them all...
simsar4's Avatar
CockyCash: 4925440
simsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot materialsimsar4 is USC mascot material
Cavenders is great on anything!!
<img src=http://img3.etsystatic.com/il_170x135.236817435.jpg border=0 alt= />
simsar4 is offline   Reply With Quote
