Welcome to Cockytalk! Thank you for visiting our forum. As a guest, you have limited access to view some discussion and articles. By joining our free community, you will be able to view all discussions and articles, post your own topics, communicate privately with other members (PM), respond to polls, upload photos, participate in Pick'Em contests and access many other special features. Registration is fast, simple and absolutely free, so please join our community today!! If you have any problems registering or logging in, please contact our Admins. Thanks! |
| Today's Top 10 | |||
| Posters (by posts) | Threads (by views) | Newest Posts | Gamecock Headlines ![]() |
Thread Tools | Display Modes |
#1 |
I need some help. Just built a computer and all seems to be great except for a few games. Crysis 3 being the main culprit, but a few others seem to have a little slow down and fps issues (Battlefield 3, Far Cry 3, etc.).
My rig is 3770-I7 cpu Intel LGA1155 DDR3 1600 ATX MOBO 16 gig ram 2 geforce evga gtx 660 ti sli Windows 8 (64 bit) I know these games are pretty intense on any machine, but I'm literally getting 10,30 fps at the most on Crysis 3 on low. Something doesn't seem right. I know a little about computers but not enough apparently. Thanks for any tips or tricks.
Class of '07. Advertising w/ a minor in film studies
#2 |
The Hero Rides Again
Male Join Date: Sep 2010
CockyCash: 200 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Everything sounds just fine. Are your graphics drivers up to date? That's the most common problem I tend to see from people that tend to have the problem you described. Go here:
http://www.nvidia.com/Download/index.aspx?lang=en-us Also, you may want to download EVGA's tuning tool, Precision X. http://www.evga.com/precision/ See what temps and clock speed you're getting from your two cards in SLI, and get back to me. |
#3 | |
I have the latest gpu driver. GPU temp is 43/27, Clock Speed 796/324 with Crysis 3 playing in background
#4 |
Winning Anyway.
Male Join Date: Sep 2007
Two things to consider: power and cooling.
What wattage is your power supply? Is it "just enough" or do you think you have power to spare? Many boards come with auxillary power inputs that you can run from the PSU to the board to give things like GPU's more juice. If any gear is running hot, that could easily be leading to less than optimal performance as well (especially GPU & CPU). Also - can you check RAM voltages, clock speeds and temp via the BIOS on your board?
Football Attendance Record: 5-0 |
#5 | |
#6 |
PSU is a thermaltake 850w. All bios are default settings. Did just bump the cpu up to 4.1 from 3.9 and a 1ghz bump on the gpu. Rosewill Thor case with some giant fans so cooling shouldn't be an issue either.
#7 |
captain of this ship
Male Join Date: Oct 2009
I dont know anything about computers but I just wanted to be included in the conversation with all the smart people, because the stuff ya'll are talking about is way over my head. Thanks for letting me chime in carry on.
#8 |
The main culprits being ruled out, look at minor areas. What HD? What speed RAM? What monitor? My first guess is that this could be a WIN 8 problem. Can you dual boot or slip in a WIN 7 HD to check that?
#9 | |
Monitor def. needs a upgrade. Its a westinghouse I've had for about 5 years now. Fiance wants a touch screen but they are running 600 and aren't good for gaming. Gonna have to two screen it to serve all purposes. The only copy of windows 7 I have is on my laptop so I can't slip a copy of windows 7 in there.
#10 |
Male Join Date: Mar 2010
CockyCash: 500 ![]() |
In my professional opinion I would blame the driver first. More than likely due to the new OS. You may be stuck until a driver is released, if this proves to be the issue. You can try installing previous releases if they exist for your OS. The next possibility is the hard drive speed. With a single drive, I would recommend solid state for the newer high graphic intensive games. If you are set on mechnical drives I would recommend going to a RAID configuration if your motherboard supports it. The RAID configuration will provide twice the Read and Writes speeds to/from the disks as well as double the amount of buffering to disk.
#11 |
Winning Anyway.
Do you have any older, less demanding games that you could perhaps install and run as a test to compare against?
Something like Crysis 1 /2, Metro 2033, Rage, Elder Scrolls (or heck, even Quake 4 or Doom 3)? When you start going down the road of drivers causing performance, yes, you can say it's the OS (I personally think Windows 8 runs fine) but drivers often get optimized over time for specific games, especially demanding ones like Crysis. Are you controlling the graphical settings via the app / game itself, or from the nVidia Control Panel (which can be set to overwrite any in-game settings - i.e. you think you're trying to run "Low" in the game but nVidia Control Panel is hard set to something like 32x AA/AF).
#12 | |
I will run fraps on Crysis 2 and tell you what I get.
#13 |
Currently getting 15-25 on Rage, Highest Settings. Crysis 2 around 15, maybe 20 fps on extreme everything (DX11 pack and Hi Res Packs patched in as well).
#14 |
What's the refresh rate on your Westinghouse? I've seen a lot of people miss the difference between 59 and 60hz and experience problems there. Also, have you tried running it with your CPU at stock? Something tells me your I7 isn't the bottleneck here, and overclocking can cause system instability if something isn't configured right.
Along with your FRAPS results, would you mind posting a DXDIAG log? Might help us get to the bottom of this easier. |
#15 | |
------------------ System Information ------------------ Time of this report: 3/2/2013, 12:08:16 Machine name: SPACEMNKY Operating System: Windows 8 64-bit (6.2, Build 9200) (9200.win8_gdr.130108-1504) Language: English (Regional Setting: English) System Manufacturer: INTEL System Model: DZ77GA BIOS: Default System BIOS Processor: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz (8 CPUs), ~3.5GHz Memory: 16384MB RAM Available OS Memory: 16352MB RAM Page File: 2909MB used, 29826MB available Windows Dir: C:\Windows DirectX Version: DirectX 11 DX Setup Parameters: Not found User DPI Setting: Using System DPI System DPI Setting: 96 DPI (100 percent) DWM DPI Scaling: Disabled DxDiag Version: 6.02.9200.16384 64bit Unicode ------------ DxDiag Notes ------------ Display Tab 1: No problems found. Sound Tab 1: No problems found. Sound Tab 2: No problems found. Sound Tab 3: No problems found. Input Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (retail) DirectDraw: 0/4 (retail) DirectInput: 0/5 (retail) DirectMusic: 0/5 (retail) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: NVIDIA GeForce GTX 660 Ti Manufacturer: NVIDIA Chip type: GeForce GTX 660 Ti DAC type: Integrated RAMDAC Device Type: Full Device Device Key: Enum\PCI\VEN_10DE&DEV_1183&SUBSYS_40693842&REV_A1 Display Memory: 4034 MB Dedicated Memory: 1986 MB Shared Memory: 2047 MB Current Mode: 1680 x 1050 (32 bit) (59Hz) Monitor Name: Generic PnP Monitor Monitor Model: LCM-22w3 Monitor Id: WDE2203 Native Mode: 1680 x 1050(p) (59.954Hz) Output Type: DVI Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,n vwgf2um,nvwgf2um Driver File Version: 9.18.0013.1407 (English) Driver Version: 9.18.13.1407 DDI Version: 11 Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1 Driver Model: WDDM 1.2 Graphics Preemption: DMA Compute Preemption: DMA Driver Attributes: Final Retail Driver Date/Size: 2/9/2013 22:25:27, 17987192 bytes WHQL Logo'd: n/a WHQL Date Stamp: n/a Device Identifier: {D7B71E3E-52C3-11CF-8D5E-64601CC2C435} Vendor ID: 0x10DE Device ID: 0x1183 SubSys ID: 0x40693842 Revision ID: 0x00A1 Driver Strong Name: oem6.inf:0f066de34a948e92:Section063:9.18.13.1407: pci\ven_10de&dev_1183 Rank Of Driver: 00E02001 Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C DXVA2 Modes: DXVA2_ModeMPEG2_IDCT DXVA2_ModeMPEG2_VLD DXVA2_ModeVC1_VLD DXVA2_ModeVC1_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeH264_VLD_NoFGT Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= D3D9 Overlay: Supported DXVA-HD: Supported DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled ------------- Sound Devices ------------- Description: Speakers (2- High Definition Audio Device) Default Sound Playback: Yes Default Voice Playback: Yes Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_8086202F& REV_1000 Manufacturer ID: 1 Product ID: 65535 Type: WDM Driver Name: HdAudio.sys Driver Version: 6.02.9200.16496 (English) Driver Attributes: Final Retail WHQL Logo'd: n/a Date and Size: 1/8/2013 22:59:47, 341504 bytes Other Files: Driver Provider: Microsoft HW Accel Level: Basic Cap Flags: 0x0 Min/Max Sample Rate: 0, 0 Static/Strm HW Mix Bufs: 0, 0 Static/Strm HW 3D Bufs: 0, 0 HW Memory: 0 Voice Management: No EAX(tm) 2.0 Listen/Src: No, No I3DL2(tm) Listen/Src: No, No Sensaura(tm) ZoomFX(tm): No Description: Digital Audio (S/PDIF) (2- High Definition Audio Device) Default Sound Playback: No Default Voice Playback: No Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_8086202F& REV_1000 Manufacturer ID: 1 Product ID: 65535 Type: WDM Driver Name: HdAudio.sys Driver Version: 6.02.9200.16496 (English) Driver Attributes: Final Retail WHQL Logo'd: n/a Date and Size: 1/8/2013 22:59:47, 341504 bytes Other Files: Driver Provider: Microsoft HW Accel Level: Basic Cap Flags: 0x0 Min/Max Sample Rate: 0, 0 Static/Strm HW Mix Bufs: 0, 0 Static/Strm HW 3D Bufs: 0, 0 HW Memory: 0 Voice Management: No EAX(tm) 2.0 Listen/Src: No, No I3DL2(tm) Listen/Src: No, No Sensaura(tm) ZoomFX(tm): No Description: Digital Audio (S/PDIF) (2- High Definition Audio Device) Default Sound Playback: No Default Voice Playback: No Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_8086202F& REV_1000 Manufacturer ID: 1 Product ID: 65535 Type: WDM Driver Name: HdAudio.sys Driver Version: 6.02.9200.16496 (English) Driver Attributes: Final Retail WHQL Logo'd: n/a Date and Size: 1/8/2013 22:59:47, 341504 bytes Other Files: Driver Provider: Microsoft HW Accel Level: Basic Cap Flags: 0x0 Min/Max Sample Rate: 0, 0 Static/Strm HW Mix Bufs: 0, 0 Static/Strm HW 3D Bufs: 0, 0 HW Memory: 0 Voice Management: No EAX(tm) 2.0 Listen/Src: No, No I3DL2(tm) Listen/Src: No, No Sensaura(tm) ZoomFX(tm): No --------------------- Sound Capture Devices --------------------- ------------------- DirectInput Devices ------------------- Device Name: Mouse Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: Keyboard Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: Razer BlackWidow Ultimate 2013 Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x1532, 0x011A FF Driver: n/a Device Name: Razer BlackWidow Ultimate 2013 Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x1532, 0x011A FF Driver: n/a Device Name: Razer BlackWidow Ultimate 2013 Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x1532, 0x011A FF Driver: n/a Device Name: Razer BlackWidow Ultimate 2013 Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x1532, 0x011A FF Driver: n/a Poll w/ Interrupt: No ----------- USB Devices ----------- + USB Root Hub | Vendor/Product ID: 0x8086, 0x1E2D | Matching Device ID: USB\ROOT_HUB20 | Service: usbhub | Driver: usbhub.sys, 9/20/2012 02:55:33, 496872 bytes | Driver: usbd.sys, 9/20/2012 02:55:32, 21736 bytes | +-+ Generic USB Hub | | Vendor/Product ID: 0x8087, 0x0024 | | Location: Port_#0001.Hub_#0001 | | Matching Device ID: USB\Class_09 | | Service: usbhub | | Driver: usbhub.sys, 9/20/2012 02:55:33, 496872 bytes | | Driver: usbd.sys, 9/20/2012 02:55:32, 21736 bytes ---------------- Gameport Devices ---------------- ------------ PS/2 Devices ------------ + HID Keyboard Device | Vendor/Product ID: 0x1532, 0x011A | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD | Service: kbdhid | Driver: kbdhid.sys, 7/25/2012 21:28:49, 29184 bytes | Driver: kbdclass.sys, 7/26/2012 00:00:52, 48368 bytes | + HID Keyboard Device | Vendor/Product ID: 0x1532, 0x011A | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD | Service: kbdhid | Driver: kbdhid.sys, 7/25/2012 21:28:49, 29184 bytes | Driver: kbdclass.sys, 7/26/2012 00:00:52, 48368 bytes | + HID-compliant mouse | Vendor/Product ID: 0x1532, 0x011A | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE | Service: mouhid | Driver: mouhid.sys, 7/25/2012 21:28:47, 26112 bytes | Driver: mouclass.sys, 7/26/2012 00:00:55, 45808 bytes | + Logitech USB TrackMan Wheel | Vendor/Product ID: 0x046D, 0xC404 | Matching Device ID: HID\VID_046D&PID_C404 | Service: mouhid | Driver: mouhid.sys, 7/25/2012 21:28:47, 26112 bytes | Driver: mouclass.sys, 7/26/2012 00:00:55, 45808 bytes ------------------------ Disk & DVD/CD-ROM Drives ------------------------ Drive: C: Free Space: 1032.6 GB Total Space: 1907.4 GB File System: NTFS Model: ST2000DM001-1CH164 Drive: D: Model: HL-DT-ST BD-RE BH14NS40 Driver: c:\windows\system32\drivers\cdrom.sys, 6.02.9200.16384 (English), 7/25/2012 21:26:36, 174080 bytes -------------- System Devices -------------- Name: Texas Instruments 1394 OHCI Compliant Host Controller Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_202F8086&REV_00\7&7DE 50A1&0&10004800E5 Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.02.9200.16384 (English), 7/25/2012 21:26:46, 226304 bytes Name: Xeon(R) processor E3-1200 v2/3rd Gen Core processor DRAM Controller - 0150 Device ID: PCI\VEN_8086&DEV_0150&SUBSYS_202F8086&REV_09\3&115 83659&0&00 Driver: n/a Name: Standard Enhanced PCI to USB Host Controller Device ID: PCI\VEN_8086&DEV_1E26&SUBSYS_202F8086&REV_04\3&115 83659&0&E8 Driver: C:\Windows\system32\drivers\usbehci.sys, 6.02.9200.16420 (English), 9/20/2012 02:55:32, 79080 bytes Driver: C:\Windows\system32\drivers\usbport.sys, 6.02.9200.16420 (English), 9/20/2012 02:55:33, 488168 bytes Driver: C:\Windows\system32\drivers\usbhub.sys, 6.02.9200.16420 (English), 9/20/2012 02:55:33, 496872 bytes Name: PCI standard PCI-to-PCI bridge Device ID: PCI\VEN_10B5&DEV_8606&SUBSYS_860610B5&REV_BA\5&27D E0F48&0&2800E5 Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.02.9200.16384 (English), 7/26/2012 00:00:55, 234224 bytes Name: Intel(R) 82579V Gigabit Network Connection #2 Device ID: PCI\VEN_8086&DEV_1503&SUBSYS_FFFF8086&REV_04\3&115 83659&0&C8 Driver: C:\Windows\system32\DRIVERS\e1i63x64.sys, 12.00.0150.0000 (English), 6/2/2012 09:31:38, 333824 bytes Name: PCI standard PCI-to-PCI bridge Device ID: PCI\VEN_10B5&DEV_8606&SUBSYS_860610B5&REV_BA\5&27D E0F48&0&2000E5 Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.02.9200.16384 (English), 7/26/2012 00:00:55, 234224 bytes Name: Standard Enhanced PCI to USB Host Controller Device ID: PCI\VEN_8086&DEV_1E2D&SUBSYS_202F8086&REV_04\3&115 83659&0&D0 Driver: C:\Windows\system32\drivers\usbehci.sys, 6.02.9200.16420 (English), 9/20/2012 02:55:32, 79080 bytes Driver: C:\Windows\system32\drivers\usbport.sys, 6.02.9200.16420 (English), 9/20/2012 02:55:33, 488168 bytes Driver: C:\Windows\system32\drivers\usbhub.sys, 6.02.9200.16420 (English), 9/20/2012 02:55:33, 496872 bytes Name: PCI standard PCI-to-PCI bridge Device ID: PCI\VEN_10B5&DEV_8606&SUBSYS_860610B5&REV_BA\5&27D E0F48&0&0800E5 Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.02.9200.16384 (English), 7/26/2012 00:00:55, 234224 bytes Name: High Definition Audio Controller Device ID: PCI\VEN_10DE&DEV_0E0A&SUBSYS_40693842&REV_A1\4&2E6 2954E&0&0109 Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.02.9200.16420 (English), 9/20/2012 01:08:44, 71168 bytes Name: Standard SATA AHCI Controller Device ID: PCI\VEN_1B4B&DEV_9172&SUBSYS_202F8086&REV_11\4&2B2 5CBD9&0&00E7 Driver: C:\Windows\system32\DRIVERS\storahci.sys, 6.02.9200.16384 (English), 7/26/2012 00:00:55, 77552 bytes Name: Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151 Device ID: PCI\VEN_8086&DEV_0151&SUBSYS_202F8086&REV_09\3&115 83659&0&08 Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.02.9200.16384 (English), 7/26/2012 00:00:55, 234224 bytes Name: Standard SATA AHCI Controller Device ID: PCI\VEN_1B4B&DEV_9172&SUBSYS_202F8086&REV_11\6&4A8 50A8&0&002000E5 Driver: C:\Windows\system32\DRIVERS\storahci.sys, 6.02.9200.16384 (English), 7/26/2012 00:00:55, 77552 bytes Name: Standard SATA AHCI Controller Device ID: PCI\VEN_8086&DEV_1E02&SUBSYS_202F8086&REV_04\3&115 83659&0&FA Driver: C:\Windows\system32\DRIVERS\storahci.sys, 6.02.9200.16384 (English), 7/26/2012 00:00:55, 77552 bytes Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 8 - 1E1E Device ID: PCI\VEN_8086&DEV_1E1E&SUBSYS_202F8086&REV_C4\3&115 83659&0&E7 Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.02.9200.16384 (English), 7/26/2012 00:00:55, 234224 bytes Name: Intel(R) Z77 Express Chipset LPC Controller - 1E44 Device ID: PCI\VEN_8086&DEV_1E44&SUBSYS_202F8086&REV_04\3&115 83659&0&F8 Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.02.9200.16384 (English), 7/26/2012 00:00:55, 17136 bytes Name: Intel(R) 82574L Gigabit Network Connection Device ID: PCI\VEN_8086&DEV_10D3&SUBSYS_202F8086&REV_00\4&3E9 A27D&0&00E4 Driver: C:\Windows\system32\DRIVERS\e1i63x64.sys, 12.00.0150.0000 (English), 6/2/2012 09:31:38, 333824 bytes Name: PCI standard PCI-to-PCI bridge Device ID: PCI\VEN_1283&DEV_8892&SUBSYS_202F8086&REV_30\6&E7D 75F0&0&004800E5 Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.02.9200.16384 (English), 7/26/2012 00:00:55, 234224 bytes Name: Intel(R) 7 Series/C216 Chipset Family SMBus Host Controller - 1E22 Device ID: PCI\VEN_8086&DEV_1E22&SUBSYS_202F8086&REV_04\3&115 83659&0&FB Driver: n/a Name: High Definition Audio Controller Device ID: PCI\VEN_10DE&DEV_0E0A&SUBSYS_40693842&REV_A1\4&19A D44D4&0&0108 Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.02.9200.16420 (English), 9/20/2012 01:08:44, 71168 bytes Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 5 - 1E18 Device ID: PCI\VEN_8086&DEV_1E18&SUBSYS_202F8086&REV_C4\3&115 83659&0&E4 Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.02.9200.16384 (English), 7/26/2012 00:00:55, 234224 bytes Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 1 - 1E10 Device ID: PCI\VEN_8086&DEV_1E10&SUBSYS_202F8086&REV_C4\3&115 83659&0&E0 Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.02.9200.16384 (English), 7/26/2012 00:00:55, 234224 bytes
#16 |
CockyCash: 5010000 ![]() ![]() ![]() ![]() ![]() ![]() |
I had an texture issue as well as a fps issue with my video card, which isnt quite as good as yours, and an ATI to boot, but a friend of mine told me to go into the gpu control panel, which for ATI is the CCC (Not sure what it is for Nvidia off the top of my head), and reset everything to default. Worked like a charm, and hasnt screwed up since, even with me tweaking.
#17 |
Hmmm. Have you tried running just one GTX and seeing how it works out? It could be the SLI. Your setup should be making Crysis cry the way it is.
#18 |
I'm starting to think it has to be the driver. One GTX runs basically the same. I got the second gpu a day or two after I picked up Crysis 3. New drivers came out the night before Crysis 3 was released.
#19 | |
Believe it or not, I'm actually running a 660Ti right now with those drivers, and I'm getting 60FPS in Metro and Skyrim with HD textures and a crap ton of particle effects. Your card is different than mine though, I'm assuming you're running 2 2GB cards in SLI? I've got just one 3GB. That's why these results are so confusing to me, because you should be running circles around my rig. Try this update. Nvidia claims it's specially made for Crysis 3 and offers a 65% performance boost. Doesn't explain why your other ones are underperforming, but it's worth a shot. |
#20 | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
