JerseyBird
FurmanCock
COCKYWOOD
rabid cock
PODCAST: The Transfe (840)
Yanny or Laurel? (13)
Clemson 5* QB Hunter (0)
2019 - Zacch Pickens
Clemson 5* QB Hunter John
Gamecocks back in collegi
AKORN GRILL FROM LOWE'S
Josh Belk
2019 - Chris Steele
Hosting as a 2 seed?
2019 - Tra Wilkins
**GAME #3 USC (31-22) vs.
2019 - Ben Smiley
Old 08-20-2013, 12:49 PM   #1
Don Giovanni
Gamecock gamer!
Don Giovanni's Avatar
Don Giovanni is USC mascot materialDon Giovanni is USC mascot materialDon Giovanni is USC mascot materialDon Giovanni is USC mascot materialDon Giovanni is USC mascot materialDon Giovanni is USC mascot materialDon Giovanni is USC mascot materialDon Giovanni is USC mascot materialDon Giovanni is USC mascot materialDon Giovanni is USC mascot materialDon Giovanni is USC mascot material
Default Offensive gameplan for UNC?
Since the last scrimmage had Spurrier complaining about the pass blocking, do you folks think the gameplan for the offense against UNC will be really run-heavy?
In spite of what was apparently a poor performance by the OL in pass protection, the running backs managed to gain good yardage in the scrimmage. In fact, the running game has worked pretty well in both scrimmages. And since UNC uses an offense that is predicated on speed that is meant to wear out the defense, I believe running the ball more should be expected to help rest the defense, if necessary.
Thoughts?
Eat! Pugnant! Vincere! Removere asinum!
Don Giovanni is offline   Reply With Quote
Old 08-20-2013, 12:54 PM   #2
CoverTwo
If C2 doesn't trust you..
CoverTwo's Avatar
2009 Awards: Awards for best Posters - Given for: Best Football Poster of 2009
CockyCash: 101200
CoverTwo is USC mascot materialCoverTwo is USC mascot materialCoverTwo is USC mascot materialCoverTwo is USC mascot materialCoverTwo is USC mascot materialCoverTwo is USC mascot materialCoverTwo is USC mascot materialCoverTwo is USC mascot materialCoverTwo is USC mascot materialCoverTwo is USC mascot materialCoverTwo is USC mascot material
Default Re: Offensive gameplan for UNC?
It'll probably be somewhat vanilla. Always is.
I do however think Spurrier will come out firing to see what his offense has that night. Results of the first handful of series will determine the rest of the game probably.
Also, worst case scenario, if the Heels are clicking on offense it might force Spurrier to go score for score.
Follow me on Twitter! @Ch4ncey
As you walk down the fairway of life you must smell the roses, for you only get to play one round. - Ben Hogan
CoverTwo is offline   Reply With Quote
Old 08-20-2013, 12:56 PM   #3
CoverTwo
CoverTwo's Avatar
CockyCash: 101200
USC has to get up on UNC to get them to lengthen their routes which will allow Clowney and company more time to get to Renner.
Old 08-20-2013, 12:59 PM   #4
Lonnie
Band
Lonnie's Avatar
CockyCash: 2001
Lonnie is USC mascot materialLonnie is USC mascot materialLonnie is USC mascot materialLonnie is USC mascot materialLonnie is USC mascot materialLonnie is USC mascot materialLonnie is USC mascot materialLonnie is USC mascot materialLonnie is USC mascot materialLonnie is USC mascot materialLonnie is USC mascot material
Get as a lead as possible then go conservative and hold the ball as long as possible.
Oh, and "Everyone has a plan until they get punched in the mouth..." - Mike Tyson.
"When you come back in January, All Gas, No Brakes. Let's get ready to roll" - Coach Will Muschamp
Lonnie is online now   Reply With Quote
Old 08-20-2013, 01:41 PM   #5
Clowneygotcha
Clowneygotcha's Avatar
Clowneygotcha is USC mascot materialClowneygotcha is USC mascot materialClowneygotcha is USC mascot materialClowneygotcha is USC mascot materialClowneygotcha is USC mascot materialClowneygotcha is USC mascot materialClowneygotcha is USC mascot materialClowneygotcha is USC mascot materialClowneygotcha is USC mascot materialClowneygotcha is USC mascot materialClowneygotcha is USC mascot material
Score more than the other guys.
Clowneygotcha is offline   Reply With Quote
Old 08-20-2013, 02:04 PM   #6
ReadR00ster's Avatar
CockyCash: 1220
ReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot material
It won't be run - heavy. It will be balanced, but I do think we should run more than pass.
ReadR00ster is offline   Reply With Quote
Old 08-20-2013, 02:11 PM   #7
ra742002
ra742002's Avatar
CockyCash: 10540
ra742002 is USC mascot materialra742002 is USC mascot materialra742002 is USC mascot materialra742002 is USC mascot materialra742002 is USC mascot materialra742002 is USC mascot materialra742002 is USC mascot materialra742002 is USC mascot materialra742002 is USC mascot materialra742002 is USC mascot materialra742002 is USC mascot material
I think you will see a game plan that resembles the one we have used versus the tiggers the last couple of seasons. After all, they run very similar offenses. They want to spread you out on offense, and go really fast- forcing your defense to play base, play after play-which makes it easy on the OC to call plays and catch guys out of position. However, what we've seen in the past, is a balanced approach by our offense to use the run when we can and try to stay ahead of the chains, making it easier to convert 3rd downs by not being in "drop back" and sling it mentality on third. This keeps the defense from being pass rush heavy and having to play the chains, instead of pin their ears back, which makes it hard on the OL to pass block. Stay ahead of the chains on first and second, convert short to medium third downs and keep our defense off the field. Take a shot when the opportunity comes and make it count! That's our recipe.
ra742002 is offline   Reply With Quote
Old 08-20-2013, 02:14 PM   #8
SCohioBoy
Buckle up, BOOM Comin'
SCohioBoy's Avatar
CockyCash: 10480
SCohioBoy is USC mascot materialSCohioBoy is USC mascot materialSCohioBoy is USC mascot materialSCohioBoy is USC mascot materialSCohioBoy is USC mascot materialSCohioBoy is USC mascot materialSCohioBoy is USC mascot materialSCohioBoy is USC mascot materialSCohioBoy is USC mascot materialSCohioBoy is USC mascot materialSCohioBoy is USC mascot material
We will start out like we did vs ECU a few years back, take a deep shot early in the game and go from there
"We played the State Championship in a place called Death Valley," he said. "I looked up in the fourth quarter and the only ones still alive were the Gamecocks."--SOS
SCohioBoy is offline   Reply With Quote
Old 08-20-2013, 02:52 PM   #9
henmania
henmania's Avatar
henmania is USC mascot materialhenmania is USC mascot materialhenmania is USC mascot materialhenmania is USC mascot materialhenmania is USC mascot materialhenmania is USC mascot materialhenmania is USC mascot materialhenmania is USC mascot materialhenmania is USC mascot materialhenmania is USC mascot materialhenmania is USC mascot material
Thoughts?
The UNC secondary is the weak part of their D. I imagine SOS will attack their weakness at least early. Once we get up on them, I expect us to go run heavy. I expect a good bit of passing early on. Our OL should be able to hold its own against the UNC DL. I expect quite of bit of crossing routes and drag routes with the TEs since that is our strength. get our big guys running in space with their weak secondary.
henmania is offline   Reply With Quote
Old 08-20-2013, 03:02 PM   #10
Cockholio
Cockholio's Avatar
Cockholio is USC mascot materialCockholio is USC mascot materialCockholio is USC mascot materialCockholio is USC mascot materialCockholio is USC mascot materialCockholio is USC mascot materialCockholio is USC mascot materialCockholio is USC mascot materialCockholio is USC mascot materialCockholio is USC mascot materialCockholio is USC mascot material
Try to establish a lead, then ball control with short passes/runs. I don't think we'll see anything out of the ordinary unless the game is not going our way/UNC jumps out in front. I don't expect much in the pocket passing game.
Cockholio is offline   Reply With Quote
Old 08-20-2013, 03:03 PM   #11
MillerTime843
MillerTime843's Avatar
CockyCash: 1135301
MillerTime843 is USC mascot materialMillerTime843 is USC mascot materialMillerTime843 is USC mascot materialMillerTime843 is USC mascot materialMillerTime843 is USC mascot materialMillerTime843 is USC mascot materialMillerTime843 is USC mascot materialMillerTime843 is USC mascot materialMillerTime843 is USC mascot materialMillerTime843 is USC mascot materialMillerTime843 is USC mascot material
A heavy pounding on the ground game....
MillerTime843 is offline   Reply With Quote
Old 08-20-2013, 03:09 PM   #12
gamecockphan
gamecockphan's Avatar
CockyCash: 102200
gamecockphan is USC mascot materialgamecockphan is USC mascot materialgamecockphan is USC mascot materialgamecockphan is USC mascot materialgamecockphan is USC mascot materialgamecockphan is USC mascot materialgamecockphan is USC mascot materialgamecockphan is USC mascot materialgamecockphan is USC mascot materialgamecockphan is USC mascot materialgamecockphan is USC mascot material
UNC can put up points (avg'd 41 per game last year). They like to spread you out and speed it up.
Hopefully our O can eat clock and keep them off the field like we did against Clemson last year.
gamecockphan is online now   Reply With Quote
Old 08-20-2013, 03:10 PM   #13
LegalCock
LegalCock's Avatar
CockyCash: 6000
LegalCock is USC mascot materialLegalCock is USC mascot materialLegalCock is USC mascot materialLegalCock is USC mascot materialLegalCock is USC mascot materialLegalCock is USC mascot materialLegalCock is USC mascot materialLegalCock is USC mascot materialLegalCock is USC mascot materialLegalCock is USC mascot materialLegalCock is USC mascot material
I think we could run it on them and control the game to minimize risk. If this game was in like week 10 I think we'd be more apt to do that, but we'll probably try and open it up and see if we can execute offense in the manner spurrier would like. It could be fairly sloppy like the last few seasons have been while we're trying to figure out "who we are".
LegalCock is offline   Reply With Quote
