AtlGAMECOCK
Three and Out
Cockhornleghorn
Senior Rooster
Gamecocks1137
GoldenSpur7
WBB Transfers (1002)
Opening weekend impr (989)
Oyster Stew (195)
2018 Men's Club Lacr (184)
Miss State Firing Ba (144)
2018 Winter Olympics thre
Oyster Stew
Former Dan Werner QB: ‘Ja
2020 - Mecose Todd
Discussion: 2018 Recruiti
Kory Holden is gone
Miss State Firing Basebal
2020 WBB - Loyal McQueen
WBB Transfers
2018 Men's Club Lacrosse
Old 09-16-2013, 07:24 PM   #1
russ472
russ472's Avatar
russ472 has hatched from the shell
Default need to be schooled
not new to the board, but my 1st post.
Always wondered when the guys line up for the extra point after a TD, why do half of the line set up on one side of the field, then move back to their normal spots while the kicker sets up? I noticed a lot of different schools doing this.
russ472 is offline   Reply With Quote
Old 09-16-2013, 07:31 PM   #2
GetSpurred
GetSpurred's Avatar
CockyCash: 466
GetSpurred is learning to peckGetSpurred is learning to peck
Default Re: need to be schooled
Well the idea behind it is this:
If the defense just assumes they're going to kick and doesn't go out there to cover the guys, then the offense will just snap it and throw it over for 2 easy points. Obviously, everybody knows this will happen and the defenders follow them out and then follow them back before the snap, but it's just a way to see if you can catch the other team off guard real quick.
GetSpurred is offline   Reply With Quote
Old 09-17-2013, 03:25 AM   #3
uscsandstorm85
uscsandstorm85's Avatar
uscsandstorm85 rules the CockPituscsandstorm85 rules the CockPituscsandstorm85 rules the CockPituscsandstorm85 rules the CockPituscsandstorm85 rules the CockPituscsandstorm85 rules the CockPituscsandstorm85 rules the CockPituscsandstorm85 rules the CockPituscsandstorm85 rules the CockPituscsandstorm85 rules the CockPituscsandstorm85 rules the CockPit
Some people do it so the defense has less time to set up and find the lanes through the offensive line.
uscsandstorm85 is offline   Reply With Quote
Old 09-17-2013, 10:13 AM   #4
"The other, more common, use of the Swinging Gate formation is on special teams, as the offensive team attempts a two-point conversion. The unusual formation allows several different attacks, one of which is a rushing attack, which, thanks to the short yardage needed, is practical in a way that isn't on an ordinary play using this formation. If in a situation where the coach finds that his team does not absolutely require a successful two-point conversion, he may give his quarterback permission to call an audible and turn the play into a field goal attempt. In this "slide," the players on the line move back to the center, the quarterback becomes the holder for a place kick, and the halfback becomes the kicker.
Some teams initially line up in the formation for every or nearly every extra-point attempt before shifting back into a conventional placekicking formation. The reasons for doing this are (1) to attempt to catch the opposing team off guard and only then try a pass or run for two points and (2) to prevent the opposing team from blocking the PAT kick. If the opposing team lines up properly to defend against a run or pass from this formation, the team will not have enough time for its players to get into position to block a kick once the offense has shifted back into a conventional placekicking formation."
