Canefaninsc
PFW79
Ironfan
Clemson 5* QB Hunter (3007)
Chris Silva returnin (773)
The Evolution Of Jad (672)
2018-AJ Lawson (609)
Yanny or Laurel? (596)
Who will fill their (427)
Hall of Fame coach H (293)
Jaylin Dickerson (152)
The Royal Wedding (103)
Chris Silva returning to
The Evolution Of Jadeveon
Hosting as a 2 seed?
Clemson 5* QB Hunter John
Jaylin Dickerson
2018-AJ Lawson
2019 - Caleb Ogunmola
Who will fill their shoes
Good News Next Week?
2019 - DJ Daniel
Old 02-16-2014, 06:04 PM   #1
COCKDIESEL
Could've been a Contender
COCKDIESEL's Avatar
CWS Baseball Pickem Winner: CWS Baseball Pickem Winner - Given for: Winning the first CWS Pickem Contest
CockyCash: 48100000
COCKDIESEL is USC mascot materialCOCKDIESEL is USC mascot materialCOCKDIESEL is USC mascot materialCOCKDIESEL is USC mascot materialCOCKDIESEL is USC mascot materialCOCKDIESEL is USC mascot materialCOCKDIESEL is USC mascot materialCOCKDIESEL is USC mascot materialCOCKDIESEL is USC mascot materialCOCKDIESEL is USC mascot materialCOCKDIESEL is USC mascot material
Default PS3 Blinking Red Light.
First off I don't wanna hear anything about xbox.
Second has anyone had success using either the hair dryer in the box or opening the console and removing and reinserting the Hard drive? I've had the thing for 7 years and this is the first problem. I'm not dropping $500 on a PS4 at this time. But if need be I'll put money down on a used PS3 but I thought I would give some of the you tube fixes first. Just wondering if anyone else had successfully brought their PS3 back from the dead?
COCKDIESEL is offline   Reply With Quote
Old 02-16-2014, 06:09 PM   #2
TaterHater1984
The Original Tater Hater
TaterHater1984's Avatar
CockyCash: 100000
TaterHater1984 is USC mascot materialTaterHater1984 is USC mascot materialTaterHater1984 is USC mascot materialTaterHater1984 is USC mascot materialTaterHater1984 is USC mascot materialTaterHater1984 is USC mascot materialTaterHater1984 is USC mascot materialTaterHater1984 is USC mascot materialTaterHater1984 is USC mascot materialTaterHater1984 is USC mascot materialTaterHater1984 is USC mascot material
Send a message via AIM to TaterHater1984
Default Re: PS3 Blinking Red Light.
I had this same problem with my fat model 4-5 years ago. I took it to a computer repair shop that works on game consoles and they were able to fix it for around $30. Then it did it again a few months later and I took it back to them, another $30, and it worked fine for another few months. The third time, I took it back and the hard drive was beyond repair. I won a new slim model on eBay for around $120 and bought it. Just from my experience, you can fix them for a little while, but it never lasts. Might just be worth buying a used PS3 or saving up for a PS4.
TaterHater1984 is offline   Reply With Quote
Old 02-16-2014, 06:12 PM   #3
COCKDIESEL
COCKDIESEL's Avatar
CockyCash: 48100000
Well I just want to get it working for a little while. 1st of all Black Flag is stuck in it right now. Second I just wanna recover from Christmas spending money on another one.
Old 02-16-2014, 06:14 PM   #4
TaterHater1984
CockyCash: 100000
Fully understandable. Whatever they did to fix it definitely worked, but it was temporary.
Old 02-16-2014, 06:35 PM   #5
ColaCock
ColaCock's Avatar
CockyCash: 6800
ColaCock is USC mascot materialColaCock is USC mascot materialColaCock is USC mascot materialColaCock is USC mascot materialColaCock is USC mascot materialColaCock is USC mascot materialColaCock is USC mascot materialColaCock is USC mascot materialColaCock is USC mascot materialColaCock is USC mascot materialColaCock is USC mascot material
Explain what it is happening to you in more detail.
My PS3 takes about 15-20 attempts to start up (otherwise, it tries and fails) until it actually "kicks in" and works fine until I turn it off. I have what some describe as the Yellow Light of Death but I also get a red light, too.
It is a pain, but it always starts up for me. Might want to keep trying.
ColaCock is offline   Reply With Quote
Old 02-16-2014, 06:41 PM   #6
COCKDIESEL
COCKDIESEL's Avatar
CockyCash: 48100000
Turns on for about 2 secs and then 3 beeps and blinking red light.
Old 02-16-2014, 07:03 PM   #7
AtlGAMECOCK
AtlGAMECOCK's Avatar
CockyCash: 964742
AtlGAMECOCK is USC mascot materialAtlGAMECOCK is USC mascot materialAtlGAMECOCK is USC mascot materialAtlGAMECOCK is USC mascot materialAtlGAMECOCK is USC mascot materialAtlGAMECOCK is USC mascot materialAtlGAMECOCK is USC mascot materialAtlGAMECOCK is USC mascot materialAtlGAMECOCK is USC mascot materialAtlGAMECOCK is USC mascot materialAtlGAMECOCK is USC mascot material
Send a message via Yahoo to AtlGAMECOCK
I had the same issue with first gen a while back and I reflowed mine successfully several times. They used lead free solder which can't withstand the heat and eventually cracks. The heat paste breaks down and no longer transfers heat to the heatsink to cool it down. If you want to keep your ps3 get it reballed that will last a while. If you are going to replace it and want the game try turning ps3 main power off then push and hold eject button as you turn main power back on. It should beep and flash then eject your disc. All of that was from memory about three years ago so hopefully it's correct. If you want to reflow , it isn't hard I can send you the videos I used.
Beware the BOOM.
AtlGAMECOCK is offline   Reply With Quote
Old 02-16-2014, 07:18 PM   #8
Cockadoo
Cockadoo's Avatar
Cockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot material
My first one did that. It's the cold solder joints. It's easy to do, just open it up and use a heat gun on the joints to try and get the solder hot enough to make contact again. There is some good vids on youtube on how to do it.
Cockadoo is offline   Reply With Quote
Old 02-16-2014, 07:24 PM   #9
COCKDIESEL
COCKDIESEL's Avatar
CockyCash: 48100000
This would probably explain the hair dryer technique. You warm up the inside with a hair dryer to try and get the joint back together. I was wondering why that would work but it kinda makes sense.
Old 02-16-2014, 07:58 PM   #10
RockRocks787
RockRocks787's Avatar
RockRocks787 is USC mascot materialRockRocks787 is USC mascot materialRockRocks787 is USC mascot materialRockRocks787 is USC mascot materialRockRocks787 is USC mascot materialRockRocks787 is USC mascot materialRockRocks787 is USC mascot materialRockRocks787 is USC mascot materialRockRocks787 is USC mascot materialRockRocks787 is USC mascot materialRockRocks787 is USC mascot material
Send a message via AIM to RockRocks787
Wow I guess I've been extremely lucky with mine (knocking on wood as I type this). I have the original 80 GB model and I've never had any issues with it.
RockRocks787 is offline   Reply With Quote
Old 02-16-2014, 08:13 PM   #11
COCKDIESEL
COCKDIESEL's Avatar
CockyCash: 48100000
I feel I have gotten my money out of it, it's a 1st gen 40gb. Had it since 2006 so I can't complain too much. Although in relative terms I also have an NES that still works so I guess I can't be super impressed with 7 years.
Old 02-16-2014, 09:02 PM   #12
Cockadoo
Cockadoo's Avatar
Lol, we have an old Atari in the barn. I bet if we hooked it up it would still play. Might have to try it.
Old 02-16-2014, 09:25 PM   #13
ColaCock
ColaCock's Avatar
CockyCash: 6800
Exactly what mine does.
3 beeps...quick yellow light and then blinking red?
If so, you may have hope. Just keep hitting the button each time it fails. It may take 15-20 times, but it just might come on. It works for me and has been enough for me to not go out and buy a new one.
Whenever it starts up, sometimes it thinks you are resetting the video settings- so you may have to select HD when it starts up and asks you.
Keep trying and let me know if it works.
Old 02-16-2014, 09:30 PM   #14
COCKDIESEL
COCKDIESEL's Avatar
CockyCash: 48100000
I tried that earlier, after I read your first post. It didn't do anything. Probably tried 30+ times.
