MountainCock
Jleo
Legalman72
LegalCock
**GAME #2 USC (0-1) (2540)
**USC (13-13) vs. Au (2101)
Kory Holden is gone (1152)
Need some legal advi (530)
Lost My Car Keys (203)
external hard drive (90)
**USC (13-13) vs. Auburn
Kory Holden is gone
Well this is depressing
2020 - Mecose Todd
**GAME #2 USC (0-1) vs. V
2018 Commitment - Bryce T
2018 Football Season - Re
**GAME #1 USC vs. VMI Thr
Discussion: 2019 Recruiti
external hard drive for X
Old 03-21-2014, 01:25 PM   #1
Mr.101's Avatar
Location: Location: Location: Location: Location: Location: Location: Location:
Mr.101 is USC mascot materialMr.101 is USC mascot materialMr.101 is USC mascot materialMr.101 is USC mascot materialMr.101 is USC mascot materialMr.101 is USC mascot materialMr.101 is USC mascot materialMr.101 is USC mascot materialMr.101 is USC mascot materialMr.101 is USC mascot materialMr.101 is USC mascot material
Default Nexus 7 wont turn on
My Nexus 7 (2012 version) is not booting up. It had around a 50% charge last night, and when I went to use it today, it didn't start, so I plugged it into the the charger. The charging indicator appeared on the screen for about 1 second, then it went away. Since then, it has done nothing. No indicator, no start up, nothing. I went to Google and did the troubleshooting thing but nothing worked.
Did my tablet just die?
Mr.101 is offline   Reply With Quote
Old 03-21-2014, 01:28 PM   #2
Heisman Winner
2000grad's Avatar
CockyCash: 1233026
2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material2000grad is USC mascot material
Default Re: Nexus 7 wont turn on
Solution
1. Disconnect the Micro USB cable (if connected) from your Nexus 7 then press and hold the power button for 15 seconds.
2. If your device doesn't start up, charge your Nexus 7 battery:
a. Connect the bundled AC adapter to your Nexus 7 then charge your device for at least an hour.
b. Press the power button again. If your Nexus 7 still won't start up, please contact ASUS customer support.
Note: Ensure that you use only the bundled Micro USB cable and AC adapter to charge your device.
2000grad is offline   Reply With Quote
Old 03-21-2014, 01:29 PM   #3
Heisman Winner
2000grad's Avatar
CockyCash: 1233026
This is a design fault in the Nexus - the battery is not fixed snugly internally and is allowed to slide back and fourth and so the connections get loose.
1) open up the back of the nexus as described in this video:
http://www.youtube.com/watch?v=G8SCcIMlb...
2) you will probably see that the connectors from the battery (large silver rectangular thing) are not secured.
3) push them back in properly, then place a small piece of card to the left of the battery to stop it sliding.
4) put the back, back on.
5) leave it re-charge for a couple of hours.
6) bingo hey presto it works!
Old 03-21-2014, 01:39 PM   #4
ccured
ccured's Avatar
CockyCash: 74000
ccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot material
The connection on mine is loose. Have to get it positioned just right or it won't charge either
ccured is offline   Reply With Quote
Old 03-21-2014, 01:42 PM   #5
Mr.101's Avatar
That's got to be it, because I can't even get into the bootloader.
Guess it's surgery time.
Old 03-21-2014, 02:51 PM   #6
Mr.101's Avatar
Thank you, 2000, that was it exactly.
Old 03-21-2014, 04:03 PM   #7
Heisman Winner
2000grad's Avatar
CockyCash: 1233026
sweet
