CockNJersey
AmonRa777
zappa
Bowen declares for N (2450)
Frank and Ray Need t (660)
NCAA bans teams usin (375)
Muschamp Interview (219)
Are modern players t (159)
Favorite Vietnam War (112)
NCAA bans teams using for
2019 - DJ Burns
**USC (20-16) vs. Presbyt
VB picks up transfer from
WBB Transfers
Frank and Ray Need to Be
Dakereon Joyners' speed..
Bowen declares for NBA dr
SOS is the new Orlando co
Are modern players too at
Old 03-28-2014, 05:14 PM   #1
kingoftheroost
kingoftheroost's Avatar
CockyCash: 100014000
kingoftheroost is USC mascot materialkingoftheroost is USC mascot materialkingoftheroost is USC mascot materialkingoftheroost is USC mascot materialkingoftheroost is USC mascot materialkingoftheroost is USC mascot materialkingoftheroost is USC mascot materialkingoftheroost is USC mascot materialkingoftheroost is USC mascot materialkingoftheroost is USC mascot materialkingoftheroost is USC mascot material
Default I'm clueless about this kind of stuff, so please help me out.
What could a problem potentially be if the front wheels of a vehicle see to be leaning inward a little? The vehicle in question is a '98 Ram. It's drivable, but I can definitely see a lean to the front wheels.
kingoftheroost is offline   Reply With Quote
Old 03-28-2014, 05:25 PM   #2
Ole Gregg
make an assessment
Ole Gregg's Avatar
CockyCash: 6567085
Ole Gregg is USC mascot materialOle Gregg is USC mascot materialOle Gregg is USC mascot materialOle Gregg is USC mascot materialOle Gregg is USC mascot materialOle Gregg is USC mascot materialOle Gregg is USC mascot materialOle Gregg is USC mascot materialOle Gregg is USC mascot materialOle Gregg is USC mascot materialOle Gregg is USC mascot material
Default Re: I'm clueless about this kind of stuff, so please help me out.
could be anything from needing alignment to needing front end parts such as ball joints and bushings. or it could be collision damage such as bent frame. if you take it to a decent alignment shop, they should be able to tell you what you need and what it will cost.
[SIGPIC][/][SIGPIC]
[/SI[SIGPIC][/]GPIC]. ww
....what you doin in my watas?want
w
" Are you playing your love games with me? "
http://www.youtube.com/watch?v=XxaP19pY1FI
Ole Gregg is offline   Reply With Quote
Old 03-28-2014, 05:29 PM   #3
ccured
ccured's Avatar
CockyCash: 74000
ccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot material
upper control arm bushings shot or bad upper ball joints more than likely if it is noticeably visible. doubtful that is an alignment issue making it that pronounced
ccured is offline   Reply With Quote
Old 03-28-2014, 05:29 PM   #4
snruter amabon
snruter amabon's Avatar
snruter amabon is USC mascot materialsnruter amabon is USC mascot materialsnruter amabon is USC mascot materialsnruter amabon is USC mascot materialsnruter amabon is USC mascot materialsnruter amabon is USC mascot materialsnruter amabon is USC mascot materialsnruter amabon is USC mascot materialsnruter amabon is USC mascot materialsnruter amabon is USC mascot materialsnruter amabon is USC mascot material
sounds like alignment. If it is something more major take it in for alignment & they will certainly let you know.
Might be ball joints
snruter amabon is offline   Reply With Quote
Old 03-28-2014, 05:33 PM   #5
kingoftheroost
Thanks guys. I was wondering if taking it to be aligned would let me find out if there are other problems in the front end, so it's good to know that should work. I'm going to hold out hope that simply getting the front end aligned will take care of the problem.
Old 03-28-2014, 05:44 PM   #6
ccured
ccured's Avatar
CockyCash: 74000
do you have clunking noise when going over bumps? or wobbly steering?
Old 03-28-2014, 05:56 PM   #7
taylorssc
Raisinballin'
taylorssc's Avatar
CockyCash: 1000337
taylorssc is USC mascot materialtaylorssc is USC mascot materialtaylorssc is USC mascot materialtaylorssc is USC mascot materialtaylorssc is USC mascot materialtaylorssc is USC mascot materialtaylorssc is USC mascot materialtaylorssc is USC mascot materialtaylorssc is USC mascot materialtaylorssc is USC mascot materialtaylorssc is USC mascot material
sounds like the problem is, you bought a dodge truck.
all kidding aside, not sure how much the repairs noted above might cost. another option may be to check govt surplus. I posted a link to a site below, it auctions off anything that is govt surplus. you can find a lot of trucks from nearby municipalities for less than $1,000. they'll let you go by and look at them too if you want before you bid.
www.govdeals.com
taylorssc is offline   Reply With Quote
Old 03-28-2014, 05:57 PM   #8
kingoftheroost
Not that I've noticed, but the sound of the engine is relatively loud, so it's possible I may have missed some noises. The steering is definitely off, but not really wobbly. When driving straight, the steering wheel is turned a fair amount to the left.
Old 03-28-2014, 05:57 PM   #9
Thenardier
Thenardier's Avatar
Thenardier is USC mascot materialThenardier is USC mascot materialThenardier is USC mascot materialThenardier is USC mascot materialThenardier is USC mascot materialThenardier is USC mascot materialThenardier is USC mascot materialThenardier is USC mascot materialThenardier is USC mascot materialThenardier is USC mascot materialThenardier is USC mascot material
that's what she said.
Thenardier is offline   Reply With Quote
Old 03-28-2014, 06:04 PM   #10
taylorssc
Raisinballin'
taylorssc's Avatar
CockyCash: 1000337
here you go, found a replacement. $650 in charleston, sc. she's a beaut!
http://www.govdeals.com/index.cfm?fa...211&acctid=539
Old 03-28-2014, 06:06 PM   #11
taylorssc
Raisinballin'
taylorssc's Avatar
CockyCash: 1000337
plenty of late 90's dodge models for under $500.
http://www.govdeals.com/index.cfm?fa...10&StartRow=61
Old 03-29-2014, 09:30 AM   #12
kingoftheroost
I've been thinking about your question, and I wonder if I misinterpreted what you meant by wobbly steering.
The steering wheel doesn't shake back and forth (I've had vehicles to do this before), and I thought that's what you meant. But there is a good bit of "play" in the steering. I said to my wife, "It's like the steering needs to be 'tightened'." Is this what you meant?
Old 03-29-2014, 04:26 PM   #13
GamecockInHell
GamecockInHell's Avatar
CockyCash: 1818785
GamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot material
Dodge trucks are notorious for front end problems. And expensive repairs. I've had two of them and my son has one and they wear out ball joints and tie-rod ends on a regular basis. I guess its because they are so heavy in the front. At least thats what I was told at one of the shops. I have a Toyota now and so far have had no front end issues.
GamecockInHell is offline   Reply With Quote
