Ironfan
Canefaninsc
Cockhornleghorn
GeoCocky66
Clemson 5* QB Hunter (2775)
Chris Silva returnin (696)
The Evolution Of Jad (583)
Yanny or Laurel? (568)
2018-AJ Lawson (432)
Who will fill their (345)
Hall of Fame coach H (277)
The Royal Wedding (14)
2018-AJ Lawson
Who will fill their shoes
Clemson 5* QB Hunter John
Good News Next Week?
Chris Silva returning to
2019 - DJ Daniel
The Evolution Of Jadeveon
2019 - Zacch Pickens
Josh Belk
Johnny Manziel Signs with
Old 08-08-2014, 01:19 PM   #1
Nassau Gamecock
Nassau Gamecock's Avatar
CockyCash: 6200
Nassau Gamecock is USC mascot materialNassau Gamecock is USC mascot materialNassau Gamecock is USC mascot materialNassau Gamecock is USC mascot materialNassau Gamecock is USC mascot materialNassau Gamecock is USC mascot materialNassau Gamecock is USC mascot materialNassau Gamecock is USC mascot materialNassau Gamecock is USC mascot materialNassau Gamecock is USC mascot materialNassau Gamecock is USC mascot material
Default R factor rating for existing building walls and roof
For a prospective tenant, I need to verify existing R values for exterior walls and the roof and if insufficient raise the value to their threshold value (13 wall, 22 roof). I doubt if anybody on the island does that- looking for them now.
If not, who does that kind of thing and can verify/certify the results - before and after installation of some kind of insulating material?
I'm guessing a thermal engineer of some sort...my nickel.
Thanks
under a coconut tree!
Nassau Gamecock is online now   Reply With Quote
Old 08-08-2014, 04:01 PM   #2
doc
doc's Avatar
CockyCash: 60000000
doc rules the CockPitdoc rules the CockPitdoc rules the CockPitdoc rules the CockPitdoc rules the CockPitdoc rules the CockPitdoc rules the CockPitdoc rules the CockPitdoc rules the CockPitdoc rules the CockPitdoc rules the CockPit
Default Re: R factor rating for existing building walls and roof
Find another tenant.
doc is offline   Reply With Quote
Old 08-08-2014, 04:04 PM   #3
l^l^lBGCock
l^l^lBGCock's Avatar
l^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot material
Boom!
l^l^lBGCock is offline   Reply With Quote
Old 08-09-2014, 03:57 PM   #4
Nassau Gamecock
CockyCash: 6200
If it works, big long term $
Really are there environmental engineers who measure this stuff?
Old 08-09-2014, 07:48 PM   #5
JaxcockFL
Cunning Linquist
JaxcockFL's Avatar
CockyCash: 1104965
JaxcockFL is USC mascot materialJaxcockFL is USC mascot materialJaxcockFL is USC mascot materialJaxcockFL is USC mascot materialJaxcockFL is USC mascot materialJaxcockFL is USC mascot materialJaxcockFL is USC mascot materialJaxcockFL is USC mascot materialJaxcockFL is USC mascot materialJaxcockFL is USC mascot materialJaxcockFL is USC mascot material
Yeah, you are looking for an energy audit of some sort. Try inspectors. Probably need a infrared camera to make sure the walls are insulated
R-13 is 4" blanket insulation in the walls, which is standard.
22 in the roof is going to depend on the type if insulation. Blanket is going to be probably 8 inches or so, maybe two runs of 4 inch, or if loose fiberglass looking at 9 inches. Here is a chart on loose insulation
http://www.northstarcomfort.com/images/R-valueChart.pdf
You should be able to figure out what is going on in the attic yourself. The walls, I would suggest taking a drill and running a hole to see if they are insulated if you have any doubt about it prior to spending money on that.
Inspection companies, contractors, architects and engineers are where I would look. May want to consider calling an insulation company to see if they can refer someone.
If your worst fears come true, you no longer have anything left to fear.
JaxcockFL is offline   Reply With Quote
