2k15
GAMEKEM
Ironfan
GregoryHouse
*** USC MBB (9-8, 4- (3704)
Ty’son Willians to x (3404)
Jake Bentley progres (1026)
2019 Preferred Walk (999)
2020- Zykevious Walk (547)
Transfer Portal (539)
2020 - Jacyais Credl (455)
Unanimous (400)
2020 - Amarius Mims (208)
A special favor need (48)
2020- Zykevious Walker
2020 - Jacyais Credle
New Football Facility
2019 - Jammie Robinson
2019 - Jaquaze Sorrells
*** USC MBB (9-8, 4-1) vs
Muschamp at Carolina and
Jake Bentley progression
How Good Can Frank's Team
Laeticia Amihere Enrolls
Old 08-25-2014, 12:56 AM   #1
ZenUSC
ZenUSC's Avatar
ZenUSC is USC mascot materialZenUSC is USC mascot materialZenUSC is USC mascot materialZenUSC is USC mascot materialZenUSC is USC mascot materialZenUSC is USC mascot materialZenUSC is USC mascot materialZenUSC is USC mascot materialZenUSC is USC mascot materialZenUSC is USC mascot materialZenUSC is USC mascot material
Default The 3-4
We aren't the only team to be introducing this new style defense. It's not just a different formation it is a radical change in football as we know it.
It means there will be less big lineman on the field. No more will we see the typical 4 big guys on the line. It means if you want to play the interior line on defense in college football there will be less demand for your services. Speed is more important than size. Big means less now. If you're going to start on the interior D you need to be better than players were just a year ago since there are fewer job openings for the big framed DL guys and more jobs for the more agile, speedy mid size guys..
The 3-4 will also cause changes on the other side of the ball too. Offenses will be able to do different things as well as not do things they used to do.
The 3-4 is not a formation change. It is a major change to the game of football as we knew it.
ZenUSC is offline   Reply With Quote
Old 08-25-2014, 01:06 AM   #2
GarnetSwarm1990
GarnetSwarm1990's Avatar
CockyCash: 5738
GarnetSwarm1990 is USC mascot materialGarnetSwarm1990 is USC mascot materialGarnetSwarm1990 is USC mascot materialGarnetSwarm1990 is USC mascot materialGarnetSwarm1990 is USC mascot materialGarnetSwarm1990 is USC mascot materialGarnetSwarm1990 is USC mascot materialGarnetSwarm1990 is USC mascot materialGarnetSwarm1990 is USC mascot materialGarnetSwarm1990 is USC mascot materialGarnetSwarm1990 is USC mascot material
Default Re: The 3-4
We won't be running it full time. Ward's base D is a 4-2-5. The 3-4 looks will be to help with coverage's and because we have a surplus of LB's that need to see the field, and a lack of DE depth.
And if we want to get technical, if Golightly is going to be on the field as part of the LB's then technically it's a 3-3-5. Or will he go off the field to make it a true 3-4?
GarnetSwarm1990 is offline   Reply With Quote
Old 08-25-2014, 01:19 AM   #3
b381l's Avatar
CockyCash: 1000365601
b381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot material
Default Re: The 3-4
The more I've read about it, the more it looks like we're going to using it. I think either Botkin or Adams said probably around 50% a few days ago.
b381l is offline   Reply With Quote
Old 08-25-2014, 01:23 AM   #4
Ed O'Bannon must pay
Order 66's Avatar
CockyCash: 10950385
Order 66 is USC mascot materialOrder 66 is USC mascot materialOrder 66 is USC mascot materialOrder 66 is USC mascot materialOrder 66 is USC mascot materialOrder 66 is USC mascot materialOrder 66 is USC mascot materialOrder 66 is USC mascot materialOrder 66 is USC mascot materialOrder 66 is USC mascot materialOrder 66 is USC mascot material
Default Re: The 3-4
Looking at our depth at DE vs DT, we had better use it at least that much.
Order 66 is offline   Reply With Quote
Old 08-25-2014, 01:26 AM   #5
b381l's Avatar
Default Re: The 3-4
When we use it, we'll just remove Dixon (DT) and add BAW (starter).....all the other players stay the same......
Old 08-25-2014, 01:33 AM   #6
Order 66's Avatar
CockyCash: 10950385
Default Re: The 3-4
Come to think of it, that's true. I guess it still get's the strength of the defense on the field.
Old 08-25-2014, 01:37 AM   #7
Regalcock
Fawlless
Regalcock's Avatar
CockyCash: 2234400758473
Regalcock is USC mascot materialRegalcock is USC mascot materialRegalcock is USC mascot materialRegalcock is USC mascot materialRegalcock is USC mascot materialRegalcock is USC mascot materialRegalcock is USC mascot materialRegalcock is USC mascot materialRegalcock is USC mascot materialRegalcock is USC mascot materialRegalcock is USC mascot material
Default Re: The 3-4
I also heard that the coaches said they were pleased to find out that Deon Green could play some DE in the 3/4 also.
Regalcock is offline   Reply With Quote
Old 08-25-2014, 01:40 AM   #8
Carolina4Life
Carolina4Life's Avatar
Carolina4Life is USC mascot materialCarolina4Life is USC mascot materialCarolina4Life is USC mascot materialCarolina4Life is USC mascot materialCarolina4Life is USC mascot materialCarolina4Life is USC mascot materialCarolina4Life is USC mascot materialCarolina4Life is USC mascot materialCarolina4Life is USC mascot materialCarolina4Life is USC mascot materialCarolina4Life is USC mascot material
Default Re: The 3-4
I'm ok with it if it works.
Carolina4Life is offline   Reply With Quote
Old 08-25-2014, 01:41 AM   #9
ZenUSC
ZenUSC's Avatar
Default Re: The 3-4
The game is changing. 300lb DLs were very valuable in the old days and very rare. However, today the game has changed to more of a speed game. LBs and DBs are more suited to catching RBs and WRs. Basically the 3-4 is a 3-8. It's 3 big guys and 8 guys that can run. I wish we had had the 3-4 last year vs Tenn. It always looked like we had one too few LBs.
Old 08-25-2014, 01:41 AM   #10
Order 66's Avatar
CockyCash: 10950385
Default Re: The 3-4
All I know is that you need more than 240 lb DE's in a 3-4 defense. Someone is going to have to draw double teams.
Old 08-25-2014, 01:41 AM   #11
PageUSC
Recruiting60%-Coaching40%
PageUSC's Avatar
CockyCash: 987375
PageUSC is USC mascot materialPageUSC is USC mascot materialPageUSC is USC mascot materialPageUSC is USC mascot materialPageUSC is USC mascot materialPageUSC is USC mascot materialPageUSC is USC mascot materialPageUSC is USC mascot materialPageUSC is USC mascot materialPageUSC is USC mascot materialPageUSC is USC mascot material
Default Re: The 3-4
This is true. There are alot of different personnel combinations we will use.
Also we still have the rabbits package.
"Yeah, Clemson can beat Virginia Tech as many times as they want, but ask them if they want another piece of South Carolina." - Colin Cowherd
PageUSC is offline   Reply With Quote
Old 08-25-2014, 01:49 AM   #12
ZenUSC
ZenUSC's Avatar
Default Re: The 3-4
The Rabbits package and the 3-4 are geared to get more speed on the field. Anotherwords Whammy isn't trying to dream up a defense with six 300lb DLs because it would be disaster. Defenses are turning away from the use of the big interior lineman.
Old 08-25-2014, 01:58 AM   #13
b381l's Avatar
Default Re: The 3-4
Getting BAW on the field to either cover in space or rush the passer is an upgrade over a DT that will be mostly a run stopper.
Old 08-25-2014, 02:01 AM   #14
b381l's Avatar
Default Re: The 3-4
plus Griffin and Lamin as well....we are loaded at DT.
Old 08-25-2014, 02:03 AM   #15
b381l's Avatar
Default Re: The 3-4
teams can't afford to double our DE....that leaves an uncovered BOB......that is much quicker than a DE.
Old 08-25-2014, 02:04 AM   #16
JoeMorrisonLives
JoeMorrisonLives's Avatar
CockyCash: 3000
JoeMorrisonLives is crowing loudlyJoeMorrisonLives is crowing loudlyJoeMorrisonLives is crowing loudlyJoeMorrisonLives is crowing loudlyJoeMorrisonLives is crowing loudlyJoeMorrisonLives is crowing loudlyJoeMorrisonLives is crowing loudlyJoeMorrisonLives is crowing loudlyJoeMorrisonLives is crowing loudlyJoeMorrisonLives is crowing loudlyJoeMorrisonLives is crowing loudly
Default Re: The 3-4
That works for passing spread teams. Spread-power is where that doesn't work. If we play Baylor, we're gonna use 4 down linemen because you need 2 DT's of 320+ to stop their guards. You beat the HUNH with depth on the DL, you need to let your second team DL go in for probably an entire drive (because you can't sub them out and the first teamers need a break) and have them still able to contain the other teams first team OL. Baylor would lose badly to LSU for example because LSU has DL depth and big CBs that can match up against big WRs and can handle press and off man coverage. If I were to choose any D to try to stop Baylor or Auburn with, I'm not going with OK's 3-3-5, I'm going with LSU or Stanford's D, or hell, for it's versatility designed for this role exactly, our base 4-2-5.
JoeMorrisonLives is offline   Reply With Quote
Old 08-25-2014, 02:09 AM   #17
Sir Cuss
Sir Cuss's Avatar
Sir Cuss is USC mascot materialSir Cuss is USC mascot materialSir Cuss is USC mascot materialSir Cuss is USC mascot materialSir Cuss is USC mascot materialSir Cuss is USC mascot materialSir Cuss is USC mascot materialSir Cuss is USC mascot materialSir Cuss is USC mascot materialSir Cuss is USC mascot materialSir Cuss is USC mascot material
Default Re: The 3-4
Not only do you need 260+ defensive ends, you need 250+ outside linebackers.
Sir Cuss is offline   Reply With Quote
Old 08-25-2014, 04:16 AM   #18
ReadR00ster's Avatar
CockyCash: 1220
ReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot materialReadR00ster is USC mascot material
Default Re: The 3-4
You also need a 325lb Nose. If you don't have those things, you get the ball run right down your throat.
ReadR00ster is offline   Reply With Quote
Old 08-25-2014, 11:50 AM   #19
Emery
Emery's Avatar
CockyCash: 11950
Emery is USC mascot materialEmery is USC mascot materialEmery is USC mascot materialEmery is USC mascot materialEmery is USC mascot materialEmery is USC mascot materialEmery is USC mascot materialEmery is USC mascot materialEmery is USC mascot materialEmery is USC mascot materialEmery is USC mascot material
Default Re: The 3-4
No offense, but I can't wait for the game so all these hypothetical discussions about the new scheme can stop. I think I've read more about 3-4, 4-3, 4-2-5, 3-3-5 over the past few months than ever before. I don't care what they run as long as teams have more trouble rushing on us than they did the last few games.
Emery is offline   Reply With Quote
Old 08-25-2014, 02:06 PM   #20
zambam
zambam's Avatar
CockyCash: 24083333
zambam is USC mascot materialzambam is USC mascot materialzambam is USC mascot materialzambam is USC mascot materialzambam is USC mascot materialzambam is USC mascot materialzambam is USC mascot materialzambam is USC mascot materialzambam is USC mascot materialzambam is USC mascot materialzambam is USC mascot material
Default Re: The 3-4
the 3-4 is a new defense?
Change the game of football? What year is this?
zambam is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
