LBC
GregoryHouse
USCBatgirl21
Daniels Island - Cha (135)
**GAME #1 USC (20-17 (96)
Hootie in Charleston (0)
Are modern players too at
AKORN GRILL FROM LOWE'S
***Green Green Grass Of H
2019 - Christian Brown
Frank and Ray Need to Be
2019 - Jashawn Sheffield
Daniels Island - Charlest
2019 - Savion Jackson
***Ace Of Spades - Men's
**GAME #1 USC (20-17) vs.
Old 08-25-2014, 03:07 PM   #1
LouiseCLaroche
LouiseCLaroche's Avatar
LouiseCLaroche has earned his spursLouiseCLaroche has earned his spursLouiseCLaroche has earned his spursLouiseCLaroche has earned his spursLouiseCLaroche has earned his spursLouiseCLaroche has earned his spurs
Default Keeping drinks cold in a cooler - When the ice melts, is it better to add more ice to
Got into an argument with a family member over this. The water in the cooler was still ice cold. In fact, there was still some unmelted ice left. My Aunt insisted that it was better to drain the water from the cooler and then add ice. I explained that water has a higher specific heat capacity than air, and should be kept in, as long as the cooler had enough space. Because of water's higher specific heat capacity, it could absorb more heat from the environment, before increasing in temperature, than an air and ice mixture could do.
LouiseCLaroche is offline   Reply With Quote
Old 08-25-2014, 03:26 PM   #2
l^l^lBGCock
l^l^lBGCock's Avatar
l^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot materiall^l^lBGCock is USC mascot material
Default Re: Keeping drinks cold in a cooler - When the ice melts, is it better to add more ic
I would dump the water out first, but by that time who the hell really cares just put the ice in the damn cooler.
l^l^lBGCock is offline   Reply With Quote
Old 08-25-2014, 03:31 PM   #3
palmettosc
palmettosc's Avatar
CockyCash: 1200
palmettosc is USC mascot materialpalmettosc is USC mascot materialpalmettosc is USC mascot materialpalmettosc is USC mascot materialpalmettosc is USC mascot materialpalmettosc is USC mascot materialpalmettosc is USC mascot materialpalmettosc is USC mascot materialpalmettosc is USC mascot materialpalmettosc is USC mascot materialpalmettosc is USC mascot material
Just get a yeti. Don't worry. I'll show myself out.
palmettosc is offline   Reply With Quote
Old 08-25-2014, 03:46 PM   #4
05USCGrad
i'm probably lying
05USCGrad's Avatar
CockyCash: 100950
05USCGrad is USC mascot material05USCGrad is USC mascot material05USCGrad is USC mascot material05USCGrad is USC mascot material05USCGrad is USC mascot material05USCGrad is USC mascot material05USCGrad is USC mascot material05USCGrad is USC mascot material05USCGrad is USC mascot material05USCGrad is USC mascot material05USCGrad is USC mascot material
add ice with the water still in there
add salt too for extra cold
clemson sucks
05USCGrad is offline   Reply With Quote
Old 08-25-2014, 03:50 PM   #5
ultimatetailgater
ultimatetailgater's Avatar
CockyCash: 5200
ultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot material
Send a message via AIM to ultimatetailgater
You are correct the ice mixed with water still stay colder than just ice. So unless you have stuff in the cooler that shouldn't be submerged in water I would leave the water. It's also a pretty well known physics trick that if you want to cool something more quickly you put it in ice mixed with water rather than just ice.
ultimatetailgater is offline   Reply With Quote
Old 08-25-2014, 04:14 PM   #6
SwampFox
SwampFox's Avatar
SwampFox is USC mascot materialSwampFox is USC mascot materialSwampFox is USC mascot materialSwampFox is USC mascot materialSwampFox is USC mascot materialSwampFox is USC mascot materialSwampFox is USC mascot materialSwampFox is USC mascot materialSwampFox is USC mascot materialSwampFox is USC mascot materialSwampFox is USC mascot material
Why do you think people look shocked when the water and ice hits during an ice bucket challenge?
Scotland Forever
http://www.undiscoveredscotland.co.u...eum/index.html
SwampFox is offline   Reply With Quote
Old 08-25-2014, 04:27 PM   #7
ccured
ccured's Avatar
CockyCash: 74000
ccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot materialccured is USC mascot material
always keep the water. if you have something that shouldn't get wet in a cooler it should be in a double zip freezer bag or rubbermaid type container
ccured is offline   Reply With Quote
Old 08-25-2014, 07:15 PM   #8
LBC
LBC's Avatar
LBC is USC mascot materialLBC is USC mascot materialLBC is USC mascot materialLBC is USC mascot materialLBC is USC mascot materialLBC is USC mascot materialLBC is USC mascot materialLBC is USC mascot materialLBC is USC mascot materialLBC is USC mascot materialLBC is USC mascot material
Air is the enemy. Always leave the water. As has been said, if it can't get wet...bag it. Otherwise rarely drain the water unless you are only doing so to make room for more ice...but always leave water.
LBC is online now   Reply With Quote
Old 08-25-2014, 07:29 PM   #9
CockinAthens
Behind enemy lines
CockinAthens's Avatar
CockyCash: 87300
CockinAthens is USC mascot materialCockinAthens is USC mascot materialCockinAthens is USC mascot materialCockinAthens is USC mascot materialCockinAthens is USC mascot materialCockinAthens is USC mascot materialCockinAthens is USC mascot materialCockinAthens is USC mascot materialCockinAthens is USC mascot materialCockinAthens is USC mascot materialCockinAthens is USC mascot material
Ice water will keep your drinks colder than just ice due to the water increasing the contact surface.
CockinAthens is offline   Reply With Quote
Old 08-25-2014, 09:34 PM   #10
Gamecocks1137
Apparent Sunshine Pumper
Gamecocks1137's Avatar
CockyCash: 1000062190122800
Gamecocks1137 is USC mascot materialGamecocks1137 is USC mascot materialGamecocks1137 is USC mascot materialGamecocks1137 is USC mascot materialGamecocks1137 is USC mascot materialGamecocks1137 is USC mascot materialGamecocks1137 is USC mascot materialGamecocks1137 is USC mascot materialGamecocks1137 is USC mascot materialGamecocks1137 is USC mascot materialGamecocks1137 is USC mascot material
Ice water keeps drinks colder than Ice. It is a proven fact. (Ice Water, is Water with pieces of ice still visible floating on top. Best way to make something as cold as you need.)
"I'd rather be anywhere other than Clemson."
Vendable Bow Youtube
Vendable Bow Twitter
Gamecocks1137 is online now   Reply With Quote
Old 08-25-2014, 10:19 PM   #11
cockymac
I was the white shadow.
cockymac's Avatar
CockyCash: 6200
cockymac is USC mascot materialcockymac is USC mascot materialcockymac is USC mascot materialcockymac is USC mascot materialcockymac is USC mascot materialcockymac is USC mascot materialcockymac is USC mascot materialcockymac is USC mascot materialcockymac is USC mascot materialcockymac is USC mascot materialcockymac is USC mascot material
The mythbusters did that experiment. It is better to have a water, ice mixture. However, it is even better to have a water, ice, and salt mixture. You can probably find the episode on YouTube.
cockymac is offline   Reply With Quote
Old 08-25-2014, 10:42 PM   #12
eightohhthree
Smokes - Let's Go!
eightohhthree's Avatar
CockyCash: 10200
eightohhthree is USC mascot materialeightohhthree is USC mascot materialeightohhthree is USC mascot materialeightohhthree is USC mascot materialeightohhthree is USC mascot materialeightohhthree is USC mascot materialeightohhthree is USC mascot materialeightohhthree is USC mascot materialeightohhthree is USC mascot materialeightohhthree is USC mascot materialeightohhthree is USC mascot material
I too have stupid family.
https://ibb.co/dLgZvG
eightohhthree is offline   Reply With Quote
Old 08-25-2014, 11:13 PM   #13
Been caught moddin'
Spur's Addiction's Avatar
CockyCash: 1001856
Spur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot material
Never drain the water - unless all the ice has melted and it has started to warm up.
Or if you have something that can't get wet. But then you should just package it better to keep the water out.
Spur's Addiction is offline   Reply With Quote
Old 08-25-2014, 11:35 PM   #14
Gaichon
Chartreuse Microbus, 10-4
Gaichon's Avatar
CockyCash: 999980500
Gaichon is USC mascot materialGaichon is USC mascot materialGaichon is USC mascot materialGaichon is USC mascot materialGaichon is USC mascot materialGaichon is USC mascot materialGaichon is USC mascot materialGaichon is USC mascot materialGaichon is USC mascot materialGaichon is USC mascot materialGaichon is USC mascot material
I'm a little amazed someone didn't believe leaving the water was the route to go.
"A nation that makes a great distinction between its scholars and its warriors will have its laws made by cowards and its wars fought by fools." - Thucydides
Gaichon is offline   Reply With Quote
Old 08-25-2014, 11:53 PM   #15
b381l's Avatar
CockyCash: 1000365601
b381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot materialb381l is USC mascot material
Aunt is correct.....ice is colder than water......the ice had to melt to become water......however, having water mixed with ice keeps drinks colder quicker because if completely covers whatever is in the cooler where ice doesn't totally cover items in the cooler.
b381l is offline   Reply With Quote
